anti seize?
Old Dec 29, 2014 | 07:39 PM
happythree's Avatar
Default anti seize?
are you guys using anti seize on plugs?
thinking of doing them just to be sure they can be loosened. any trouble of stuck plugs?
Old Dec 29, 2014 | 07:46 PM
woodwardsh3's Avatar
I all ways use anti seize it is cheep insurance.
and with aluminum heads it is very important to use anti seize
Old Dec 30, 2014 | 12:14 AM
Jetnc's Avatar
Anti seize on spark plugs is not a good idea. It changes the torque by adding lubrication, can lessen electrical contact if it isn't conductive. I've never used it in any of my cars.
Old Dec 30, 2014 | 09:26 AM
Not needed at all. Spark plug torque is 18N.m/13 lb ft, possible seizing is a non-issue.
Old Jan 8, 2015 | 09:38 PM
norinco3264's Avatar
When I did my first spark plug change in 2014 I used anti seize on the new ones. Soon after my CEL came on and it was a cyl 5 misfire.
Maybe the anti seize contributed to it?
Old Jan 8, 2015 | 10:40 PM
I use anti-seize on my glow plugs but they stay in for 100,000 miles.
Old Jan 9, 2015 | 01:28 AM
whylee's Avatar
It is always recommended to use anti seize on plugs in aluminum heads. You do not need to overdue it with the anti seize, just a lite coating is all thats needed. I have been using it for 20 years without a problem.
The only problems I have had is removing plugs that did not have it on to begin with.
Old Jan 9, 2015 | 08:43 AM
I have heard people say that before, and I have heard of people saying they had a stuck plug in an aluminum head. I have never had that problem, I started playing with aluminum heads on LT1 Vette motors, and then small and big block Olds motors in the 70s. However, I am always super careful about the spark plug torque (I stripped one on a snowmobile in the early 70s and stranded my azz miles from the nearest road .... about froze stiff before somebody came by for a lift).
If you over torque and mash the threads, over time that could cause an issue. I will agree that if used correctly like whylee suggests, it won't hurt anything. IMH experience, I just don't see where there is a need for it.
HummerGuy
Jul 12, 2007 08:22 AM
HummerGuy
Feb 20, 2007 10:53 AM
JDEORTA
Nov 5, 2006 11:16 AM
OUTLAW
Feb 16, 2006 12:15 AM
Rayvyn
Nov 25, 2005 07:09 AM
