Amber turn signals / Clear DRL's
Old Apr 16, 2008 | 06:01 PM
LookAgain79's Avatar
Default Amber turn signals / Clear DRL's
Well, without any luck usingthe search function, I am forced to make a post asking. As many of you know i have a early 2006 H3. One that uses the DRL and the front turn signals in the same bulb. I have purchased the clear front turn signals from ebay. Now, by federal law, all turn signals are supposed to be amber. Is there a light that will flash amber when i am using the turn signals. Or is there a way to disable the DRL's so that with an amber bulb they would only come on when i use the turn signals.?[&:]
Old Apr 16, 2008 | 07:20 PM
alrock's Avatar
Default RE: Amber turn signals / Clear DRL's
They are sometimes called stealth bulbs. I have the Sylvania SilverStars, # 3157. Silver when off, amber when lit.
Here's the thread.
https://www.hummerforums.com/m_73450/tm.htm
Old Apr 16, 2008 | 08:37 PM
I'm hoping that the nearest Autozone will have these. Do you remeber about how much they ran?
Old Apr 16, 2008 | 08:42 PM
rhill20's Avatar
I pulled out the fuse for the DRL's, but the 07/08's use the headlights so I'm not sure if it would be the same one. #39 I think. Check your panel. Everything still works normal, just no DRL's. Help's with the blacked (murdered) out look.
Old Apr 16, 2008 | 08:45 PM
I'll have to get out there under the hood and take a look tonight. Thanks for the tips there guys.
Old Apr 16, 2008 | 11:35 PM
alrock's Avatar
I don't recall what I paid for them. I see them from $10-$20 for a pair.
Old Apr 17, 2008 | 11:09 AM
Great news. I got the lights in with the new bulbs this morning. I purchased the Sylvania Silerstar part # 3157A (got them for $10 and some change at Advance Auto Parts) and they work perfect. I also took rhill20's info and removed the DRL fuse ( it was # 39 btw) and problem solved. Thanks again for everyones help and info. I will post some pics later on.
Old Apr 17, 2008 | 08:44 PM
rhill20's Avatar
Glad it worked out.
Old Apr 17, 2008 | 09:45 PM
Ghostrider's Avatar
ORIGINAL: rhill20
FYI, late 06's also used headlights.
Old Apr 17, 2008 | 09:55 PM
rhill20's Avatar
Sorry, our 06 was an earlier model.
jlopez
Aug 30, 2013 06:28 PM
Peej Willys
Apr 25, 2009 09:01 AM
tarheel_34
Jan 29, 2008 08:51 AM
Heysdad
Nov 5, 2007 08:25 AM
hsbertiii
Feb 13, 2007 10:14 PM
