Amber turn signals / Clear DRL's
Well, without any luck usingthe search function, I am forced to make a post asking. As many of you know i have a early 2006 H3. One that uses the DRL and the front turn signals in the same bulb. I have purchased the clear front turn signals from ebay. Now, by federal law, all turn signals are supposed to be amber. Is there a light that will flash amber when i am using the turn signals. Or is there a way to disable the DRL's so that with an amber bulb they would only come on when i use the turn signals.?[&:]
They are sometimes called stealth bulbs. I have the Sylvania SilverStars, # 3157. Silver when off, amber when lit.
Here's the thread.
https://www.hummerforums.com/m_73450/tm.htm
Here's the thread.
I pulled out the fuse for the DRL's, but the 07/08's use the headlights so I'm not sure if it would be the same one. #39 I think. Check your panel. Everything still works normal, just no DRL's. Help's with the blacked (murdered
) out look.
) out look.
Great news. I got the lights in with the new bulbs this morning. I purchased the Sylvania Silerstar part # 3157A (got them for $10 and some change at Advance Auto Parts) and they work perfect. I also took rhill20's info and removed the DRL fuse ( it was # 39 btw) and problem solved. Thanks again for everyones help and info. I will post some pics later on.
jlopez
Aug 30, 2013 06:28 PM
Peej Willys
Apr 25, 2009 09:01 AM
