Airaid filter , MPG drop ?
Old Oct 12, 2014 | 02:36 PM
H2Miami's Avatar
Default Airaid filter , MPG drop ?
After checking the OEM intake filter prices I decided to go with the
Airaid 721-182 . Which will perform better and was washable .
However I noticed a drop in the MPG , could be coincidence but 2 days after installing the filter the MPG drop from the usual 10.5-11 to 9.5 ...
My biggest concern is the way the filter suck the air , not from the end ( as the OEM) but from around sides ..
In my opinion airaid had much better air flow tan OEM but the OEM gets air right from the vent . could this be an issue .. anyone had same/different experience after installing the Airaid filter ..
Check pics
Old Oct 12, 2014 | 07:14 PM
yoymon's Avatar
haven't had same experience but maybe airflow being changed computer still learning adjusting? id give it a whole tank to see how it does maybe 2, I don't know how the computer reacts to changes immediately
Old Oct 12, 2014 | 07:46 PM
H2Miami's Avatar
I was searching for online info and everyone seems to be happy with Airaid , noone complains about Mpg . Could be a coincidence
Im going to reset the Avg Mpg and mix the drive btw hwy and city to see what I get . Unfortunately I trow the OEM filter a switch Would had be a good idea
Old Oct 13, 2014 | 12:22 PM
ak47dennis's Avatar
Check pics
Attachment 7791
Attachment 7792
Yup sounds about right (I noticed a drop in the MPG) order to make more HP you need more fuel & Air
I have mentioned it here many times ....
Old Oct 13, 2014 | 01:23 PM
H2Miami's Avatar
I didnt notice a big change in the HP , also yes more fuel and air may be needed for supplying more HP but in this case I dont think replacing the filter give more HP . At least not noticeably for a 1.5MPG drop
If the MPG drop is real then I assume the cause is the lack of sucking air directly from the vent ..
I will reset the mpg and test it for a couple fuel tanks if not positive results then replace the Airaid for the stuck filter
Old Oct 13, 2014 | 07:26 PM
H2Miami's Avatar
Angry getting worse
GReset the mpg for the worse. Now the number drop to 8.5mpg wtf ..
only drove for a few miles but anyway I never saw such low numbers even driving in city after resetting.
Will allow the filter for a few days more before switch back to the OM .
so disappointed. I really like the airaid, also was planning to get a airdoc . Now I don't know if any change on the intake is worth it.
With a 2600 miles road trip coming every mile point counts
what most bother me is to not find any other complain. May be the only who notice the mpg drop . Hopefully it os only the filter
... update ..... 2 hours after write the post above . I took the truck for a drive (couldn't sleep counting mpg ). Less traffic but still city drive . After 10-15 miles the Mpg is showing 10-11. Hopefully after a few days will gets around 10.5 stable .
looks like a mix between reset the mpg and the comp had to relearn with the new filter that less air restrictions doesn't mean lower mpg
I will update in a few days
Oh yes my previous post was hysterical and frustrating Well I guess we all had bad days ...
Good night folks
Old Oct 14, 2014 | 05:23 AM
badss98's Avatar
If your road trip involves coming to the midwest region you can expect a decrease in mpg as we have switched to winter blend gasoline in all cold weather states. I will usually see a 10% drop in mpg during our season as the ethanol is increased for cold weather start up.
Old Oct 14, 2014 | 07:41 AM
H2Miami's Avatar
Unfortunately the trip wont included Midwest . I had planned a trip to Wy before but way too far . Need 7 days only for drive .
this time going Miami- west Virginia - west NY - Niagara , On then NY city then miami
Not sure if the same problem will be found on the NE area
Old Oct 15, 2014 | 05:17 AM
ak47dennis's Avatar
Coming north you will encounter winter blend. If you come thru Pa we can meet up, and I can follow you back out of the decaying Northeast
Old Oct 15, 2014 | 08:29 AM
H2Miami's Avatar
Yes Im going up thru PA .. Im stopping on the Carnegie Museum . Would likr to meet you but my way up schedule is very tight and due to the last stop in NY city the way back is route 95 .
Still not sure if we are coming back that way or PA , I would like to stop in NC too
I will post a few days before departing , if coming back thru PA for sure we can meet and you may follow me to the sunshine state .. Should I said Rainy state (rains everyday)
