Air suspension problem
Old Dec 2, 2007 | 12:25 PM
marines's Avatar
Default Air suspension problem
Hello,
I have searched the forum bought thought I would ask anyway...
2003 H2 with air susp, I woke up to find the rear right air spring empty causing my beast to sag on the rear right side. I turined on the truck and turned on the compressor (leveler button), nothing happened except the compressor turned on and I saw the rear right raise slightly. I then turned off the truck and could hear from the rear right side the air spring leaking air...
question, sounds like I need a new air spring, how much does this usully cost...?
hopefully it is just the line but I doubt it...
thanks...
Old Dec 2, 2007 | 11:17 PM
dizzy's Avatar
Default RE: Air suspension problem
Hopefully the air leak is just an air line or fitting. This should be a cheap fix.
Old Dec 7, 2007 | 04:17 PM
Deviant0191's Avatar
I had the same problem in my 03 Hummer, it took about one day to fix and cost about +600$ cause both of my suspension in the rear were leaking
PzYkED
Jan 5, 2012 02:41 PM
HeyUvaVT
18
Aug 20, 2011 06:42 AM
TT_2004H2
Dec 30, 2010 08:03 PM
moni
Apr 29, 2009 05:49 PM
matelblapav
Mar 27, 2008 06:47 PM
