Air suspension problem
Hello,
I have searched the forum bought thought I would ask anyway... 2003 H2 with air susp, I woke up to find the rear right air spring empty causing my beast to sag on the rear right side. I turined on the truck and turned on the compressor (leveler button), nothing happened except the compressor turned on and I saw the rear right raise slightly. I then turned off the truck and could hear from the rear right side the air spring leaking air... question, sounds like I need a new air spring, how much does this usully cost...? hopefully it is just the line but I doubt it... thanks... |
RE: Air suspension problem
Hopefully the air leak is just an air line or fitting. This should be a cheap fix.
I had the same problem in my 03 Hummer, it took about one day to fix and cost about +600$ cause both of my suspension in the rear were leaking
