air suspension problem
Old Sep 13, 2008 | 03:44 AM
moni's Avatar
Default air suspension problem
hello everybody
i need help- in my H2 i had a warning- service air suspension. i tried to press the electric button on the dashboard, but then the car went down totaly and i have no suspension at all. what happened? what should i do? there is no sound of air pump. thanks
Old Sep 13, 2008 | 03:46 AM
moni's Avatar
Default RE: air suspension problem
hello eveybody
i have a problem- my dashboard warning is service air suspenasion. i push the air button in the consule, and then the car went down and i cannot lift up. no sound of compression and no movement. can you advise what to do?
thanks
Old Apr 27, 2009 | 03:49 PM
Strutmastr's Avatar
It sounds to me like your compressor got killed. What probably happened is that the airbag got a hole or tiny crack in it so the compressor has to work extra hard because it is like blowing up a balloon with a hole in it. Therefor the airbag killed the compressor. I would recommend going to strutmasters.com and taking a look at our conversion kits. these convert you from the airbag to a powder coated American made steel coil spring that is guaranteed to last the life of the car. I added the link below so you can check it out.
http://www.strutmasters.com/hummer-h...nsion-s/97.htm
I hope I was of some help
Good Luck!!!
Old Apr 29, 2009 | 05:49 PM
Circuitguy's Avatar
This happens offen with some H2 owners from 2003 all the way to the new 2009. Take the H2 to your local dealer so they can see what codes are currently in the computer, bet they will find some there as the light is on. Most fixes are just programing updates. Most of the time it will cost nothing to check it out.
PzYkED
Jan 5, 2012 02:41 PM
HeyUvaVT
18
Aug 20, 2011 06:42 AM
TT_2004H2
Dec 30, 2010 08:03 PM
matelblapav
Mar 27, 2008 06:47 PM
marines
Dec 7, 2007 04:17 PM
