Air suspension to coil spring conversion- Need advice
Old Nov 28, 2016 | 10:38 PM
H_drizzie's Avatar
Default Air suspension to coil spring conversion- Need advice
Hey there,
Do you guys think it is a good idea to convert from air suspension to coil spring? Is the ride going to be the same or is it going to be a major difference? Btw it's an H2 with a lift kit on it. Thanks
Old Nov 29, 2016 | 08:19 AM
Synthetickiller's Avatar
The consensus among all hummer forums is that the air ride is a lot more maintenance & is frowned upon for that reason, alone.
If you don't mind replacing air bags, then stick with it. Some people argue that there's no difference, but I've noticed that most people say it's noticeably better.
Old Dec 2, 2016 | 01:28 PM
calif phil's Avatar
I have had both and can't tell the difference in ride quality. If it was just the low cost and easy to replace air bags, I would keep the air ride. If the high dollar compressor went out I would go with the conversion. Arnott is the company I would use.
AndyMac
Feb 3, 2024 10:44 AM
masterpogi
Apr 13, 2014 07:10 PM
sagev
Jan 17, 2013 11:41 AM
itsxthexslim
Apr 7, 2012 11:04 AM
AZ Hummer
Mar 22, 2008 07:12 PM
