Air Conditioning Problem..HELP
Old Jun 8, 2006 | 09:00 PM
G Man's Avatar
Default Air Conditioning Problem..HELP
Leaving work today, I turned on the AC but nothing is blowing out the vents. I hear the clutch engaging on the compressor, the interior control panel is functioning, so I guess it must be a bad blower motor. I have checked all the fuses and relays as well, and they appear to be good. Anybody had this problem yet? I guess it's back to the dealer AGAIN!!![:@][:@][:@]
Old Jun 8, 2006 | 09:05 PM
Linus Gump's Avatar
Default RE: Air Conditioning Problem..HELP
If you try it on heat and you still get nothing then yup its back to the dealer.
Old Jun 9, 2006 | 12:59 PM
G Man's Avatar
It is the dash control panel that is defective. No signal is being sent from the unit to the blower motor. Part is being overnighted from the Ft. Worth warehouse, and should be installed tomorrow. [sm=rolleyes.gif]
Old Jun 9, 2006 | 03:47 PM
dilo2001gt's Avatar
Good to hear that.
Old Jun 9, 2006 | 08:45 PM
G Man's Avatar
Update.....
After further research by the tech, he has discovered a melted pin on the connector(14 pin) of the main wiring harness that runs under the dash. The entire harness has to be replaced because the plug is not available separately. The entire dash has to be pulled, and any wiring from my alarm system that has to be cut, will be my responsability to have re-installed. The harness will not arrive at the dealership until next Wednesday at the earliest, and then the installation will have to be done from there. It's really hard to enjoy this vehicle when it seems to spend as much time at the dealership as it does at home. [:'(] It's averaging one trip in for warranty work per month over the past five months of ownership.
Old Jun 17, 2006 | 06:33 PM
G Man's Avatar
Got the H3 back yesterday. The verdict....."Unacceptable Pin Tension". Apparently, if there is not enough slack in the harness, and the connector plug is under tension, the pins don not seat correctly causing an arc across the connections. I'm just glad they didn't have to pull the dash out and install a new wiring harness. The plug was located through GM from the manufacture, and was able to be replaced.
Lampooner
Oct 1, 2017 06:43 PM
AutoRoc
Sep 21, 2017 07:44 AM
Starboy0720
21
Sep 20, 2017 08:58 AM
lifted89chevy
Apr 20, 2010 04:33 PM
Intercooled
Aug 18, 2005 07:02 PM
