After market differential lockers for H3T?
Old Feb 22, 2011 | 11:20 AM
Googly1's Avatar
Default After market differential lockers for H3T?
I've given up on researching this and have decided just to ask; anyone know of an aftermarket locker for the H3T? Do the H3 applications cross over (do we share the same drivechain components). And for future reference, where can I find info like this for myself??
Old Feb 22, 2011 | 01:15 PM
Arb (air) or Eaton (electric and is what GM used for its OEM lockers).
H3s and H3Ts have the same suspension and drive train (except for the rear drive shaft is longer for the T).
Search forums and google .... etc.
Old Feb 24, 2011 | 10:00 AM
Googly1's Avatar
excellent...thanks.
Old Feb 25, 2011 | 10:36 PM
CARdiac's Avatar
I was looking at the Eaton but it looks like it only comes in the 2.75 for the H3, I have the Alpha with the 3.1 gears.. I am assuming adding the 2.75 is not a good idea
Old Feb 26, 2011 | 12:21 PM
Ummm Ahhhhh Ummmmm, What you talkin' bout Willis?
I5s have 4:56 gears and V8s have 4:10 gears plus Eaton makes the OEM lockers for both the I5s and V8s in the Adventure/OffRoad packages in 2009 and 2010 H3/H3Ts.
All V8s will also have the Cast Iron front diff (08/09/10), Only the Adventure/OffRoad I5s will have the Cast Iron front diff (09/10). The rest of the I5s will have the Alum. front diff. I would not recomend puting a front locker in an Alum. front diff. They have case deflection (twisting internally) issues that cause blown ring gears, sheared teeth on the pinion gear and broken shafts.
Old Feb 26, 2011 | 03:41 PM
CARdiac's Avatar
Yeah bit of a brain fart there
Old Feb 28, 2011 | 01:52 PM
Willis here. Like I said the 3 and 3T are the same. You still have to compare apples to apples (alpha to alpha and I5 to I5) Doh.
Old Feb 28, 2011 | 01:57 PM
The OEM lockers in any Alpha are Eatons, so yes you can buy an Eaton on ebay for your Alpha.
climbnh
Jan 9, 2012 07:06 PM
hearseman
Oct 19, 2008 10:35 PM
DH
Jan 22, 2007 07:23 AM
MPRTKLR
23
Oct 17, 2006 12:01 PM
MPRTKLR
Oct 13, 2006 08:50 AM
