ac blower wont turn off ;-(
Old May 24, 2014 | 05:21 PM
hmer's Avatar
Default ac blower wont turn off ;-(
so my lovely wife calls me today and tells me that after she started plying with the 2 memory buttons on the drivers door the ac went on and the ac blower wont stop at all even after she hit the off butrons even when the H2 its off it wont turn off at all so when she got home all i did was pull the fuse off . Any ideas what the problem may be ???? Bad resistor ?????
Old Nov 12, 2015 | 08:39 AM
mikeb686's Avatar
Question ac/heater blower won't turn off
The blower stays on in my 2006 H-2 SUT when the engine is completely shut down. It blows all night and leaves me with a dead battery some mornings. Did you fix your prob?
Any ideas?
Old Nov 12, 2015 | 08:42 AM
mikeb686's Avatar
-Also if I take the 40 amp fuse out of the engine compartment it shuts the blower off of course but doesn't fix the problem. Help
Old Nov 13, 2015 | 06:13 AM
hmer's Avatar
Your blower motor resistor is out and must be replaced . you need to get acces to the blower motor and check if you see any water around your blower motor this may be causing the resistor to go out ..
Old Nov 13, 2015 | 08:41 AM
honda400ex2003's Avatar
You have a bad resistor as hmer stated. just went through almost the same issue, i burned up a fan and a bunch of other things though.
i too think i got water in everything at one time and roasted it all, i replaced the controller, the resistor, and the blower fan. Module repair pro will rebuild the controller and the resistor, they are on ebay.
i couldnt find a new one from any gm dealer, carquest, or auto zone but it sounds like rock auto may have one around still. it would be worth calling them to find out (i just found this out yesterday). i dont really care any more as i finally got all of my stuff rebuilt and installed with success. i had about $275 in rebuilding everything and ended up having to buy the resistor twice since i roasted mine 3 times. i assumed that he figured it was my fault and not his parts so he charged me for another whole resistor rebuild...
anyway, good luck on them
steve
Old Nov 13, 2015 | 08:42 AM
cjshelby
Aug 28, 2023 09:55 PM
simota1
Nov 24, 2021 12:45 PM
Selandbe
Nov 12, 2015 01:44 PM
seagull67
Oct 7, 2012 09:49 AM
Alex2012
Jul 12, 2012 06:22 PM
