abrupt shifting
Old Jan 20, 2014 | 02:04 AM
skipper55's Avatar
Default abrupt shifting
Im new to this forum and I hope I can find a heplful community here
the vehicle is a 2007 H3 with 119 K on the mileage
while driving in heavy traffic , you have to start -break repeatedly over a long period of time ;the shifting from 1st to second gear is not smooth , in fact it shifts abruptly almost like someone bumped into the rear of the vehicle...otherwise , in high gears all is well
anyone with suggestions please
thank you
Old Jan 20, 2014 | 05:16 AM
happythree's Avatar
post in h3 section.
this is for "forum" help
you checked/changed fluid?
Old Jan 21, 2014 | 12:56 PM
Moved for you.
The HF Forum Help and Suggestion Center is for questions on using the forum's features..... like, how to post a pic.... and has nothing to do with vehicles.
Old Jan 22, 2014 | 04:04 PM
RickStang's Avatar
First thing check your fluid level and make sure it's correct.
Hard shifting only from 1-2 could be a clutch pack going bad. Could also be higher line pressure or a partially stuck shift valve.
Get it scanned if you don't have a scanner of your own.
And go from there.
All the best
Old Jan 22, 2014 | 05:22 PM
06RedH3's Avatar
You know I have the same 1-2 shift and never bothered looking into it...should I? It does not bother me unless its going to be a bigger problem someday. I have canged the transmission fluid.
Old Jan 22, 2014 | 05:29 PM
Exact thing was happening to mine when I purchased it @70k miles. I flushed the trans with BG equipment, BG quick clean, BG conditioner, and 16qts of dex VI fluid. Never had it happen again since.. GL
DMW5150
Feb 20, 2015 03:29 PM
dleotaud
Sep 14, 2009 06:15 PM
FreebornHummer
Mar 13, 2009 01:41 PM
ducati996
Apr 18, 2008 12:36 PM
HummerH2
Mar 13, 2008 12:04 PM
