5.3 ticking engine noise please help.
Old Sep 25, 2009 | 10:28 AM
Little Monster's Avatar
I remember back in the 70's when I was one of them back yard machanics the Chevy 327 was known to tick. I was called the infamous Chevy tick. The reason was that the hole through the push rods that lifts the lifters were too small to deliver the correct amount of oil needed to supress the lifters. We solved the problem by putting in a higher presure oil pump and frequent oil flushes and changes.
I had an 05 Avalanche with the 5.3 in it. it had all kinds of head issues. 1 set was worped. 1 set had too small of return springs on the lifters which caused a slight tick on acceleration. This is the truck I traded in for my 06 H3.
Everyone has given good info. Hope they find the problem. Good luck to you
Old Sep 25, 2009 | 06:40 PM
Hondo Hummer's Avatar
i hear the same thing on my 07 h3 cant figure it out eather
Old Sep 26, 2009 | 12:05 PM
canuckZr2's Avatar
Originally Posted by THE BEAST
I have checked all these thing you guys told me and none of these related to that noise
Also oils do not matter in brands, as long as GM recommends GFS4 (you will find that on the back of the oil quart) and my truck takes 5w-30, you can use any oil with 5w-30.
all the top brands have been tested by GM on all their engines and the engine wear and oil consumption and velocity are the same.
Why I know this because I am a engine test cell operator
If anyone has an alpha V8 please H3 or H3T please pay attention at this noise because there is a team of problem solving engineers that need to know about other H3s
You can also run a 15-40 (yes its for a dissel) its the last oil on the market that has Zinc in it (anti ware properties) with out a problem BUT you have to change the oil every 3000 miles. I have been running it in my Race car and my ZR2 with out a problem (its also reomended to have 5-30) As a millwright I had to learn a thing or two about oil as well
Old Sep 27, 2009 | 07:41 AM
SCOT's Avatar
i have the 5.3 in my awd express, and yes there is a tick noise, pos chevy lol
Old Sep 27, 2009 | 09:07 PM
canuckZr2's Avatar
it that tick when you first start it? if it is then it could be piston slap common on any production motor with a forged piston, after a few minnits the the tick will go away
Old Oct 3, 2009 | 07:00 AM
Turn the radio up...Problem solved.
Old Oct 23, 2009 | 03:30 AM
2wheelmonster's Avatar
what octane gas are you using?
nathanandthekid@hotmail.com
Jun 12, 2014 01:11 PM
ekeef
Dec 14, 2012 09:54 AM
H3DONIST
Dec 7, 2010 01:40 PM
mdavis
Jul 15, 2010 03:10 PM
HammerDown
Aug 30, 2007 04:54 PM
