4wd problems on my 93 H1
Old Aug 31, 2008 | 11:27 AM
Todd's Avatar
Default 4wd problems on my 93 H1
My 4wd drive hasn't worked for a couple weeks but I haven't needed it, but we just got a lot of rain at the ranch and I need 4wd. I checked all the fuses and its plugged in but its not engaging. A while back I got stuck pretty bad and heard a loud pop and it hasn't worked since. Also since then its constantly says T/C locked in H/L H & L actually now that I think of it, it doesn't even work in H just H/L or L which that is when the T/C is locked.
What do you guys suggest? Any ideas?
Old Aug 31, 2008 | 11:35 AM
phazer42's Avatar
Default RE: 4wd problems on my 93 H1
sounds like you broke a half-shaft
it won't work because when the t-case is in H, the power goes to the path of least resistance.... which means th one with the broken shaft.... when you put it in HL or L it locks the output so the front and rear get the same power.....
sounds like you need a new halfshaft....
Old Aug 31, 2008 | 11:46 AM
Todd's Avatar
Thanks for the reply.
These Hummers are spanish to me, does a half shaft require a t-case rebuild? It still delivers good power to the rear wheels but the front gets nothing. So by locking the t/c it will allow it to work?
Old Aug 31, 2008 | 02:26 PM
Todd's Avatar
ORIGINAL: phazer42
You are exactly correct. My driver front half shaft is snapped in two near the brake.
Thanks!
Old Sep 1, 2008 | 12:43 AM
and your TC should be fine unless you did something else to it.
Old Sep 1, 2008 | 11:06 PM
Todd's Avatar
I ordered all the parts to fix it yesterday. Now I need to add ball joints to the list. I blew out an upper ball joint today.
Old Sep 2, 2008 | 09:36 AM
phazer42's Avatar
I hope you aren't driving it on pavement while the truck is in lock..... that will evenually require a t/c rebuild.....
Old Sep 2, 2008 | 10:13 AM
Todd's Avatar
Just a little pavement time. [:'(]
Old Sep 2, 2008 | 11:26 AM
hummech's Avatar
the 93 Hummer h1's had lite duty halfshafts in them so you are mosy likely going to be getting the newer heavy duty one. the halfshafts were built in as the weak link to break when a tire is spinning and hard brake pressure is applied. the tire weighs over 100 lbs and the brakes are inboard, so when you apply the brakes the drive line stops and the tire tries to keep spinning and snap goes the halfshaft.
just so preventive advise.
rtwash
Dec 13, 2013 10:45 PM
ReadyGun
Dec 9, 2013 03:23 PM
Hummer79
Jan 1, 2013 04:59 PM
intogaming
Oct 28, 2011 12:30 PM
Sundrop Addict
16
Mar 2, 2010 08:41 AM
