4hi lock & 4 hi open shift problems
Old Aug 1, 2017 | 04:22 PM
Murf Davis's Avatar
Default 4hi lock & 4 hi open shift problems
I noticed My 2006 h3 was in 4hi lock. How? I have no idea. I pushed the 4hi button, it lit up but is still operating in lock mode. PLEASE HELP, I've already ordered a new shift fork. Any help & advice would be greatly appreciated
Old Aug 2, 2017 | 09:25 AM
Welcome to HF. We have this strange set up here where when you have a vehicle question, it should be posted in that vehicle section. Example, H3 questions go in the H3 section.
Have you ever owned a 4wd vehicle before? Try the basics, like driving in reverse a short distance and turning back and forth in a safe open area. Then try to shift the T Case to Hi Lock and back to Hi. Do this 3 or 4 times.
When you drive in Hi Lock on dry pavement you bind up the gears and tension prevents the shift encoder from unlocking the T Case, driving in reverse with some turning here and there may unload that pent up tension so that it can then shift.
You could also just have a bad connection to the T Case shift module/encoder, or need a new one. Get under it and take a look for frayed wired, broken connector, dirt and crud in the connector.
Has this truck been stuck in deep water for any length of time before this problem occurred?
ChevyChad
Feb 20, 2019 09:47 PM
sonyjuve25
Jan 15, 2017 02:04 PM
2003hummerH2
Jun 17, 2016 09:33 PM
IllusionX
17
Apr 1, 2015 05:05 AM
haiminger
Dec 2, 2007 02:26 PM
