315's and stock rims
Old Oct 15, 2009 | 03:26 PM
Stavros1011's Avatar
So you have your MTR's on your standard h3 rims? And there's no problem?
Old Oct 15, 2009 | 03:55 PM
08H3's Avatar
Originally Posted by oruna1
That the tires will come off the beads is silly. The stk rim is 7 1/2" wide and goodyear want's an 8" rim.
http://picasaweb.google.com/rhoffroader/OFFROAD2009#
It's not silly or made up. There is an increased likliehood of that, however it's EXTREMELY small difference between it being on a 7 1/2" and 8" rim. You are also correct about the contact patch being distorted due to the size. As you said, not a big deal either. I have no reservations or fear when I load up my family in the H3 with 315's on 7.5" rims.
We can argue semantics and details all day long. My main point is that the original dealer was not 100% BS'ing you. There was some logic behind what you were told. How big of a deal is it? That's what you'll need to decide for yourself.
By the way, oruna, great pics!
Old Oct 15, 2009 | 06:14 PM
Thanks for your input, it's appreciated and certainly taken into consideration
Old Oct 16, 2009 | 01:31 AM
2wheelmonster's Avatar
just do it
Old Oct 16, 2009 | 01:46 AM
DAGKANA's Avatar
Ive been running 315/75/16 Terra Grapplers for about a year now, 10k plus mileage and have had the under heavy load... Pulling another rig, air'd down to 15psi and never blew a bead... Ive done mild to wild wheelin with them as well, and 5hr long drives... nothing... I did get a flat twice though, once was a 7in screw, the other was a sidewall puncture when I didn't air down and went wheelin...
Im planning on ordering a set of 315s M/Ts in the morning actually...
Old Oct 16, 2009 | 09:12 AM
08H3's Avatar
"M/T's" as in Mickey Thompson's or as in Mud Terrains? Either way be sure to post up some pics when you get them on!
Old Oct 16, 2009 | 02:25 PM
Wrongway1's Avatar
That the tires will come off the beads is silly. The stk rim is 7 1/2" wide and goodyear want's an 8" rim. What happens is the tread will not be quite as flat as a 8" rim but there is no problem. I purchased a spare set of rims off e bay and mtd a set of 315 Goodyear MTR's with Kevlar. I drove them about 6500 miles on a vacation and had absolutly no problem whatsoever. Here is a link to a bunch of pics of the vacation and you'll notice the tires. You don't have to raise the front end either. I did on mine for a little additional clearance but when I first put them on (un lifted) I had no problems. On a hard turn they rub slightly on the sway bar. No big deal.
Nice Pictures. Exactly where is this??
Old Oct 18, 2009 | 04:30 PM
oruna1's Avatar
Thanks, it was a great trip that was about 2 1/2 weeks long.
Smiley Rock in very close to Jerome, Az,
Oak Creek, Soldiers pass, Broken Arrow are in Sedona,AZ
Elephant Hill is in Moab, UT
Remainder are close to Breckenridge Colorado
Old Oct 19, 2009 | 02:05 PM
Flulougs73's Avatar
Default 315s and stock rims
Im pretty sure as long as you know how to change a tire and use tape youll be fine. I havent done mine yet but they look like theyd be really easy to do. Do you think ES rims would look good blacked out?
Old Oct 19, 2009 | 10:50 PM
BudClydes's Avatar
when i get my 3t im leveling and actually putting the same tires(315 duratracs) and putting a fifth wheel on it and supercharging it...when i load up the fifth wheel trailer and 2 draft horses totaling about 6000lbs with that be considered a heavy load that would blow the tires?
