2009 H3T Aplha Performance Upgrades
Old Apr 8, 2018 | 08:59 AM
sweetlou's Avatar
Default 2009 H3T Aplha Performance Upgrades
I see several older post but was wanting some recent info
I looking for a cold air intake. Online did not see the traditional type for the V8.
Also going to install a new exhaust system. I have a very good muffler shop that can do work. Will get them to check my catalytic converters. I see that there are several different mufflers. Would like a little more rumble but not real loud. Finally a tuner that will adjust for the 35s so speedometer and odometer will be correct. I just want a little more throttle response and better mpg
2009 H3T Aplha 120000 miles
Old Apr 8, 2018 | 11:54 AM
RKSmith163's Avatar
AirDoc CAI, Tune from PCM of NC. Lots of posts on both.
Old Apr 8, 2018 | 02:41 PM
X2, not really going to get better MPG. But you will get better performance.
Old Apr 9, 2018 | 08:23 PM
sweetlou's Avatar
Default Programmers
Thanks for the info
working my tail off right now. But looking forward to the upgrades
Old Apr 17, 2018 | 03:18 PM
emetdw's Avatar
Definitely PCM of NC tune, that made the biggest difference for my truck. I have the GM Performance exhaust and Airdoc intake and those didn't make much of a performance increase. The tune removes a lot of the GM torque management which will make a huge difference with your throttle response. I had the 2nd gear shift tightened up too which was nice.
Old Apr 28, 2018 | 08:00 AM
JerseyCoast's Avatar
I own a 3.7L, but wanted to offer this info. Have had K&N CAI for few years, removed resonator and had cheap AutoZone type pipe running to TB .
Decided to replace that pipe with the Airdoc recently because it's a better quality but also because it has a true 3.5" inside diameter. Took about a week or so for it to settle in with PCM, but I see a big difference from the 3" pipe .
Take same commute since I bought H3 and noticed I'm doing about 82-84mph at 2400 rpm now when I was always about 71-73mph at that same rpm. ( same stretch of highway everyday) its become a routine for me, I find that sweet spot on tach and just drive. I feel a much better response too on the entrance ramp & from a dead stop .
I put this off for a while and regret waiting this long to do it . That cheap $40-$50 stuff was restricting some volume it seems and it made a difference.
Now that's on the I5, so I imagine you would see better results. I may be wrong...not sure.
The PCM tune is plus as well, but they ask about intake before doing it . May want to research the Airdoc. Good luck
djadds
20
May 16, 2013 09:37 AM
tgk7203
Apr 1, 2011 10:18 AM
mr300
Feb 16, 2010 04:57 PM
Captkirk
23
Mar 3, 2009 02:31 AM
ramsesthedog
May 9, 2006 04:22 PM
