2009 20" tire pressures
Old Sep 21, 2010 | 02:05 PM
Fred's Hummer's Avatar
Default 2009 20" tire pressures
I just bought a set of 2009 OEM 20" wheels with stock Goodyear Wrangler LT305/60R20 tires. What are the recommended tire pressures on the H2? The sidewall states 50 psi max, but I would think Hummer recommends less. I don't know anyone with a 2009 to check their door jamb for the recommendations. Thank you if you can help me. Did a search, but nada. This is the wheel and tire.
Old Sep 21, 2010 | 02:07 PM
This photo shows how different the 17" and 20" look.
Old Sep 21, 2010 | 05:07 PM
DTS62284's Avatar
Look in your door jam should be the same regardless of the rim and tire size, I believe it 32psi. If it doesn't say on the door then check you owners manual. The new tires look great.
Old Sep 22, 2010 | 11:23 AM
Thanks DTS, generally as with other vehicles I own, pressures were different with different profile tires, I would think it would be true here too. My door jamb says 37 psi for 70 series, these are 60 series. I am looking for someone who has a 2009 who can look on the door jamb for the actual printed recommendation. I have a call into the Hummer dealer's service dept. I'll post it if no one else steps in to help.
Old Sep 22, 2010 | 11:52 AM
TheLimoGuy's Avatar
The 20 looks much better than the 17 on yours. Good choice. As for the printed recommendation on a 09 I don't know the answer but it's certainly less than the 50 written on the sidewall. 35 is probably just about right and will give you a good ride and good wear until you find the technically correct answer.
Old Sep 22, 2010 | 05:04 PM
twr's Avatar
twr
Hi this is for your new 20" tires its 42 psi cold, Nice rims!!
Old Sep 22, 2010 | 05:42 PM
Thanks Limoguy, I think they look better too. I've been looking for a set for a year, finally someone locally upgraded to 24's and sold me all five 20's for a fair price! I do miss the meaty tires on the 17's. The 17's I had were the limited edition 2007 wheels, so I liked them too.
Tracy, you are the shizzle! That's exactly what I was looking for. I had 45 psi in them, now I know the facts. I appreciate the picture and the time you took to do it.
Old Sep 22, 2010 | 06:08 PM
twr's Avatar
twr
Hi Fred, glad i could help!
Old Sep 22, 2010 | 06:54 PM
SD90's Avatar
I have a 2008 and it says 42 PSI on the door as well.
bsg424
Jan 17, 2020 10:51 AM
jason rappe
Jan 21, 2014 07:30 PM
tillie1001
New Member Area
Sep 13, 2012 07:22 AM
schmegeggie
Mar 11, 2009 11:33 AM
