2008 h3 rattle noise on cold start up
Old Jul 10, 2013 | 08:20 PM
buster3436's Avatar
Default 2008 h3 rattle noise on cold start up
I have a 2008 h3 with 51000 miles on it when i start it up cold it makes a rattle or rumming noise took to a dealer today and they said that they are not sure what it is they will try again tomorrow to figure it out any ideas thanks
Old Aug 7, 2013 | 01:16 AM
scoreh3's Avatar
Mine was doing that and it would stop when it warmed up. It turned out to be a very large crack in the exhaust manifold . The raddle was the exhaust gas hitting the heat shield. The manifold is part of the emission warranty . My H3 had a little over 70k on it and was still covered.
Old Aug 7, 2013 | 01:20 AM
scoreh3's Avatar
ok its been a long day that should have read rattle not raddle sorry.
Old Aug 10, 2013 | 06:45 AM
chrome_eater's Avatar
Exhaust heat shield rattle when cold is a common problem - look for missing or loose exhaust heat shield bolts.
Old Aug 11, 2013 | 10:27 AM
nrkrall's Avatar
would this happen only at certain RPMs? I have something similar that only happens until the '06 warms up a bit. It only happens at or around 1000RPMs (whether idling or in motion). A very annoying, loud rattling sound. After the car is on for a minute or so, or at RPMs other than 1000, it is perfectly quiet. Any ideas??
Old Aug 13, 2013 | 02:44 PM
Otto7668's Avatar
Mine does the same thing, I have an 07 just hit 70k and this noise is driving me crazy, so I should check out the heat shield or look for a crack in the manifold?
Old Aug 16, 2013 | 11:36 PM
scoreh3's Avatar
Ok mine stopped making that rattle after the dealer replaced my exhaust manifold. Now that everyone is talking about their rattles , mine started again and IT'S LOUD !!!! When I pulled in the driveway and stopped, it stopped. I looked under , over , in front , behind, nothing . I drove around the block and it rattled again. Now it's time to just park it and start touching everything I could find. Ok I found it , it's the heat shield over the right motor mount. I pulled it up a little and now after a 4 mile road test NO noise. I hope this works for you too.
Old Aug 17, 2013 | 12:24 AM
happythree's Avatar
Default resonance
it vibrates at a resonant frequency
Old Aug 17, 2013 | 11:05 AM
scoreh3's Avatar
If it's like mine was , it's pitch/tone will change with rpm's ... You don't have to move the shield very much , just get up off of the motor mount a little... It's a 30 sec fix . I just drove 20 miles and no rattle .
Mcarter64
Jul 13, 2020 06:32 PM
DRIVER534
18
Aug 29, 2012 02:17 PM
Hummer2006h3
May 30, 2011 02:01 PM
Daytona Hummer
Jan 23, 2008 11:28 AM
FREDDY0514
Aug 10, 2007 12:26 AM
