2008 h3 alpha ac blowing warm air
Old May 25, 2014 | 12:31 PM
daniel5455's Avatar
Default 2008 h3 alpha ac blowing warm air
When I turn on ac I hear the clutch going on and off and I feel warm air coming out of the vents. I added Freon and same thing. I also recalibrated it and still same issue. Anyone have any other suggestions My H3 only has 50k on it so I hope nothing major is the issue.
Old May 26, 2014 | 10:44 AM
DennisH3's Avatar
My 08 had the same problem (middle of July) with less than 10K miles. The condenser had to be replaced and it sat at the dealer for a week until the part arrived.
Old May 29, 2014 | 05:09 PM
Reineke's Avatar
The clutch cycling on and off is due to either a low pressure or a high pressure. Normally, it will be due to having too little freon in the system. Step 1 should be to take it to an AC repair place. They well evacuate the freon, pull a vacuum on the line (which may indicate a leak in the system at this time), and recharge the system with the correct amount of freon. This usually costs ~$50-75. They should be able to point you in the right direction.
Old May 29, 2014 | 11:20 PM
Happy Hummer's Avatar
Conversely you could save some doe and buy a can of sealer freon in a can for a fraction of the cost and be on your way. JMHO. Your mileage will vary.
Chris
Old May 30, 2014 | 07:37 AM
happythree's Avatar
Default step one,yeah
"a can of sealer freon in a can "
ive done that in other caes. be aware that if you do need to have it serviced,that sealer plugging up their eqpt makes them mad!
i have trbl with "qoutes!!"
Old May 30, 2014 | 05:04 PM
Reineke's Avatar
Yeah, the sealer is definately not the way to go. The H3 AC system is simple enough that most leaks can be easily identified and fixed for not a whole lot of money. If you had a Suburban with rear AC and you had a leak, then it could start to get tricky. The can of sealer can also cause oriface tubes and other valves to become plugged, which will eventually block freon flow. Fixes in a bottle do not always fix the problem, but they usually cause more problems down the road.
DC_Roller
Jan 24, 2014 07:58 PM
jcap
Jul 2, 2010 05:55 AM
advsleep
Jan 6, 2010 08:24 AM
FLCHRIS
Nov 6, 2009 11:04 AM
Wrdabney
Sep 15, 2009 11:09 PM
