2007 Hummer H3 AC problem help!!
Old Jul 7, 2017 | 02:26 PM
DustinDorman's Avatar
Default 2007 Hummer H3 AC problem help!!
I recently purchased a 2007 hummer h3 and was working out some kinks. Ac was working perfectly well. I pulled the dash face off to work on the radio and when I put it back on, ac no longer works. It blows air on all settings but none of the lights shine when I press the buttons, temp control isn't working, and the position selector isn't working. Please help I live in south Texas and it's 104 outside.
Old Jul 7, 2017 | 03:04 PM
Hello Dustin, welcome to HF.
Look at the easiest stuff first. The HVAC controls move with the dash panel, so look to see if you still have a firm and correct connection of the wiring to the controls, maybe it became partially disconnected when you were doing the radio work?
Old Jul 7, 2017 | 08:59 PM
Default Dang
I looked and reconnected them and still no Bueno. What could be the next step?
Old Jul 8, 2017 | 06:34 AM
BruceS's Avatar
Did you recalibrate the controls after pulling panel?
Old Jul 8, 2017 | 09:52 AM
Default No
No I did not, how is that done?
Old Jul 8, 2017 | 03:37 PM
BruceS's Avatar
If I remember correctly
Temp **** all the way to hot
Fan speed on 4
Right **** all the way to left
Push and hold left and right **** until they start to flash
System will cycle through all modes then it's calibrated
Old Jul 8, 2017 | 06:34 PM
Default Fixed
Thank Y'all so much for your help. It was a weird fix. I went to reinstall the radio and whenever I hooked up the radio to power, my ac button lights came back on and ac started working again. Unplugged my radio power and same thing happened, they all stopped working. I'm guessing on the 2007 hummers the radio completes a circuit because they all go into the same harness.
Old Jul 9, 2017 | 08:42 AM
wfturner's Avatar
BruceS instructions are correct, but here is another version
Old Jul 9, 2017 | 09:46 AM
happythree's Avatar
you can unhook radio and all should work.
ive had all conn unplugged a dozen times and never had to calibrate.
i just plug them in securely.
madmajd
18
Jun 20, 2016 06:33 AM
r.spoonemore
Feb 3, 2013 10:29 AM
banditt135
Jan 4, 2010 03:51 PM
mosgerila1
Mar 3, 2007 03:08 PM
