2007 H3 no start
I recently purchased a 2007 h3 with 99 thousand miles. I got in it the other day and it cranked and wouldn't start. The radio says locked and the security light on the dash flaws and goes off. I waited the 10 minutes and still had a no start even after about 8 hours. What can cause this?
ITs been at the shop for two days. They have no clue what it can be. They just know that it is for the security. I ordered a ecm from pcm of nc with the passlock deactivated just to see if that will fix it.
#PIT4841: No Crank No Start Security Light On IP B2960 DTC Set - keywords indicator lamp nocrank nostart theft - (Apr 9, 2009)
Subject: No Crank No Start Security Light On IP B2960 DTC Set
Models: 2006-2009 Chevrolet Colorado2006-2009 GMC Canyon2006-2009 Hummer H3 and H3TThe following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<a id="d75672e24">Condition/Concern:A customer may comment on the security light illuminated in the IP with a no crank no start concern. When performing diagnostics, the technician may find DTC B2960 within the BCM. This is most likely caused by the ignition switch.
<a id="d75672e33">Recommendation/Instructions:Replace the ignition switch with current SPO parts.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Models: 2006-2009 Chevrolet Colorado2006-2009 GMC Canyon2006-2009 Hummer H3 and H3TThe following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. <a id="d75672e24">Condition/Concern:A customer may comment on the security light illuminated in the IP with a no crank no start concern. When performing diagnostics, the technician may find DTC B2960 within the BCM. This is most likely caused by the ignition switch.
marsstar102
Feb 29, 2012 06:14 PM
