2006 vrs. 2008
Old Nov 14, 2017 | 01:05 PM
Aaajaws's Avatar
Default 2006 vrs. 2008
Hello
i am looking to get an H3 Need something very snow worthy for my girl. 06 much more affordable than. 08 but have been told 06. I5 Much more louder almost irritating then 08. I did drive an 08. Was nice and quiet. Is it true Also any other reason to go with 08 ?
Want something very soon snows flying
thanks in advance for ALL responses
Old Nov 14, 2017 | 01:26 PM
I do not know where you got your information, but the sound level of a 3.5 L52 I5 vs 3.7 LLR I5 GM Atlas motors identical in design except for the larger bore size in the 3.7L would sound as near identical as is possible to compare as they have essentially the same exhaust.
The 3.7L built after April 1, 2006 (all of them in the 2008) will have the corrected hardened valve seats in its head. That alone is the reason to look for a 2008 vs 2006. Many of the 2006s have had their original heads replaced now, so that would be less of a current issue.
If you do look at 2006s, you want one with a serial # higher than 287591, the build date should be after Nov. 2006 to rule out a bad first design head flaw if you do not have confirmation that the truck has a newer head.
Old Nov 14, 2017 | 03:52 PM
Aaajaws's Avatar
My info Must have been from someone with a bad exhaust............ THANK YOU very much though now I know what to look for if I do get her an 06 for build date after Nov 06 and SERIAL # or ask about replaced head. Best regards... Jaws .
Old Nov 14, 2017 | 04:21 PM
BruceS's Avatar
Personally I would go 07 or newer. Stay with 3.7 or 5.3 (08 or newer) if funds allowed. 3.7 has slightly more power than 3.5.
Old Nov 14, 2017 | 05:00 PM
a0128's Avatar
From an interior stand point the 2008 had a redesigned driver's side window switch setup. Much improved over the 2006 / 2007.
Old Nov 14, 2017 | 06:20 PM
BruceS's Avatar
Some 07s had the arm rest and switches that were forward as well. My 07 did not so I changed the door panels. They are much easier to see and use now.
Old Nov 16, 2017 | 12:39 PM
Bunger's Avatar
Yes, that was a mid year change.
My 07 has the controls on the slant.
Old Nov 21, 2017 | 07:20 PM
norinco3264's Avatar
My 2006 H3's VIN falls within the range of bad cylinder heads, and hasn't been replaced. 94,000 miles and have seen a cylinder 5 misfire code approx 5 times. She has a terrible idle in the winter (replaced coil packs, new air filter, camshaft position sensors, super clean throttle body, stinger terminals, MAF sensor cleaned etc). Header bolts look ok. Under powered and the arm rest controls are miserable! Made for T-Rex!! But, I still love her... she's never left me stranded.
Aaajaws
Nov 14, 2017 11:58 AM
Beast05
Oct 13, 2011 12:42 PM
hummer3
Sep 12, 2009 02:07 AM
rhill20
39
Jul 14, 2008 04:50 PM
moho
17
Apr 17, 2008 11:33 AM
