2003 H2 Dash Lights
Old Mar 14, 2009 | 09:06 PM
Dragracer_Rob's Avatar
Default 2003 H2 Dash Lights
One of the lights behind my speedo is dead. How hard is it to replace?
Rob
Old Apr 18, 2009 | 12:47 PM
Unhappy Found the answer
Had to go to the dealer for a hub problem. Asked the tech about it. Have to replace the whole spedo - tach pod (about $300). Can't replace a light bulb.
Old Apr 30, 2009 | 07:11 PM
SafariHummerH2's Avatar
Hello,
Depending on which cluster type you have...
If you have incandescent lamps, you can replace the bulbs yourself as needed.
If you have LED's, then you have to bring in the whole cluster in for servicing or in your case, replacing.
I guess they stopped servicing these LED type clusters and now they just replace them.
You can remove the cluster yourself and check which type your vehicle has.
This way you can be sure if the serviceman was correct about replacing the cluster.
Safari Hummer H2
hollywood_x
18
Jul 11, 2017 09:44 PM
hollywood_x
Oct 16, 2011 02:46 AM
ejsmall
Oct 3, 2011 07:15 PM
peliti27
Aug 2, 2007 03:14 PM
