2003 H2 Air Suspension Help Needed!
Old Nov 30, 2015 | 01:47 PM
mmesa005's Avatar
Default 2003 H2 Air Suspension Help Needed!
Hello All,
I have a 2003 H2 with 117k miles. Today the compressor started running and would not turn off. After several minutes of running I hear a hissing / air pressure release sound and then the compressor continues to run. I looked at both air shocks and they appear to be equally inflated with no noticeable cracks or ruptures.
Is this a symptom of a bad air shock or a sensor or? What should I check for next?
Thank you!
Old Dec 1, 2015 | 08:49 AM
calif phil's Avatar
Its most likely bad air bags. They are not that expensive and fairly easy to replace. If you don't replace them you will burn up your compressor and that is big $$
Old Dec 18, 2015 | 11:58 PM
mmesa005's Avatar
Default Update
Just back from a business trip and replaced the air shocks. The compressor continued to cycle on/off so I took the H2 to the dealer this afternoon. They hooked the car up to a diagnostic scanner and found a bad relay on the compressor board. Should have that replaced on Monday and have the H2 back on the road!
Unfortunately while at the dealers they found a water pump leak so that will get replaced as well.
Old Dec 21, 2015 | 01:47 PM
calif phil's Avatar
Sounds like a good dealer looking out for you.
PewterTank
Dec 9, 2019 01:41 PM
Tony1
Dec 19, 2013 06:52 AM
crewj
Feb 28, 2012 09:30 PM
calif phil
Feb 25, 2011 01:00 PM
ejdelong
May 6, 2007 05:09 PM
