09 - H3 Base Clunking Sound
Old Dec 22, 2017 | 10:35 AM
Bruno Gerardo's Avatar
Default 09 - H3 Base Clunking Sound
Hello
I have a mysterious sound. I had a bad wheel bearing, switched it out, had a bad cv shaft, switched it out and another sized part which I switched it out.
The vehicle continues to the make the sound. The mechanic down the street has no clue spent 4hrs trying to figure out and thinks it may be transmission issue.
The vehicle makes this exact sound.
Old Dec 22, 2017 | 10:43 AM
Welcome to HF.
Miles on the vehicle???
Have you done any modifications to the front, like T Bar leveling? If so, what is the dimension from lip of the front fender to center of the front hub.
Bit confused about the cv shaft description... did you replace the original with an ACDelco GM Half shaft or are you using cheap junk? I as because some of the foreign trash replacement parts available are too short and the spline for the shaft can pull out of the front diff enough to cause the damage.
Old Dec 22, 2017 | 10:45 AM
Car has 94,000 miles
The bill states Right New CV Complete Assembly which was GM brand $452 to replace it by the guy, but clearly was not the issue
Old Dec 22, 2017 | 10:46 AM
The noise was happening prior to the changes of parts.. was doing process of elimination .
Old Dec 22, 2017 | 11:08 AM
Happy Hummer's Avatar
Wow! Holy bat boomerang bat man!!!
That sounds bad...
I'd start by verifying that the differential support was present and accounted for with zero damage.
I'd make sure that you were indeed sold ac delco parts and that they are properly installed.
I'd make sure both CV shafts were inspected and replaced with proper ones.
I'd check to see if you have a failing ball joint, upper a arm, lower a arm or torsion bar.
You may want to get a second opinion from another qualified tech.
Old Dec 22, 2017 | 11:13 AM
And if my parts look up is correct the CV axle should be
AC Delco 15886012
Make absolutely sure that is what you bought
Old Dec 22, 2017 | 12:43 PM
Sounds to me like the Front Differential Axle Output Shaft, Spider gears or Pinion is missing some teeth. Stop driving it! You can do a ton more damage with pieces flipping around in your diff.
Part #21, #37-#43 or Part #34
This is what happens when you drive on a broken shaft or pinion
Part is supposed to look like this
Old Dec 22, 2017 | 04:38 PM
thanks will take a look at that . what is the name of that part?
Old Dec 24, 2017 | 12:16 PM
Update: Switched out the other wheel bearing on the other, the sound stop just like previously. Last time I drove 500KMS before it did it again. Will give it a try
hollywould
Sep 28, 2018 11:09 AM
txlatinotx
Apr 14, 2013 03:43 AM
Chad
20
Dec 26, 2011 05:19 AM
jriemy
May 29, 2010 11:54 PM
Assass1n
Mar 31, 2010 01:55 PM
