07 H3 wipers acting up
Old Nov 19, 2011 | 01:33 PM
sledneck05's Avatar
Default 07 H3 wipers acting up
The wifes 07 h3 has a wiper problem, the other day she was driving and the wipers froze in the middle of the winshield and the only way they would continue was to change the selector. the will work continusly on high setting but also when the vehicle is started they come on and cycle 3 times and stop wherever they feel like it, took it to the chevy dealer to find out if they have any tsb or recall and they said no and that BCM was the problem. 300$ fort the part and atleast an hour of labor. anybody have this problem and is there any way to buy a BCM that is programmed and install it myself?
Old Nov 19, 2011 | 01:42 PM
gotafish's Avatar
Had same problem on my 08. Dealer replaced wiper motor, problem solved.
Old Nov 19, 2011 | 05:00 PM
sledneck05's Avatar
right on did they say what was wrong with the motor that caused it to go out?
hectour's Avatar
I have the same problem. It just started earlier this week. Mine too is an 07. I was told that it was the switch that controls the speed. So its def the motor?
Old Nov 19, 2011 | 05:17 PM
kooj 68's Avatar
Had a issue with my back wiper came on all by it self , Found out that alot of people had the same issue , the board in the wiper motors would get wet and cause problems , pulled mine out dried it up and resealed it no more issues
Old Nov 19, 2011 | 06:22 PM
gotafish's Avatar
Never said,just said it was motor,happened to have one in stock,replaced,all good.
Old Nov 19, 2011 | 10:12 PM
sledneck05's Avatar
might try that first where is the wiper motor? on the fire wall?
Old Nov 20, 2011 | 07:48 AM
gotafish's Avatar
I believe you have to pop off fake vents near wipers,it sits under them i believe.
Old Nov 26, 2011 | 02:18 PM
sledneck05's Avatar
you mean the square plastic pieces above the fenders? then take the wiper arms off and the plastic vent piece under the arms? how does that plastic vent piece come off?
Old May 14, 2012 | 04:11 PM
hectour's Avatar
Mine just started doing this. So replacing the wiper motor resolves the problem?
