05H2 - timing chain kits and oil pumps
Old May 13, 2023 | 10:58 AM
Daniel Z's Avatar
Default 05H2 - timing chain kits and oil pumps
Looking for recommendations for an oil pump and timing chain kit for an 05H2. About to replace the water pump soon so might as well replace the above as well. Last time I did the front seal the chain had some slack but didn’t replace it then. Part# appreciated. If I should replace something else while doing all this work let me know. After this will be the rear seal which I believe is a lot of work. Never ending project with our high mileage truck.
thanks.
Old May 13, 2023 | 12:10 PM
legerwn's Avatar
I would stay with OEM
This is what is listed at GMPartsGiant for a 05H2;
OEM Oil pump, 12710303
Timing chain, 12646386
Front cover, crank seal, 12585673
Water pump gasket, 12630223
Front engine cover gasket, 12633904
Engine oil pan gasket, 12611384, 12612350 (corrected part number)
Neal
Old May 13, 2023 | 12:31 PM
Daniel Z's Avatar
Appreciate the info and quick response. Looks like I’ll be bugging you for the rear seal info as well
Old May 13, 2023 | 04:59 PM
legerwn's Avatar
Rear main brg, seal, 89060436
Old May 13, 2023 | 06:02 PM
Timken manufactures the oem seals(compare the price, same part different label)
front and rear:
Old May 13, 2023 | 06:34 PM
Look @ what happens when Timken 100085 & 100470 uses the blue label box:
Old May 13, 2023 | 08:27 PM
legerwn's Avatar
Yep, and OEM are even more expensive but are the best and offer the same service as when the truck was new
Neal
Old May 13, 2023 | 08:30 PM
legerwn's Avatar
AC Delco is not OEM, they are the aftermarket side of GM, they offer replacement parts for GM vehicles, they are a very good alternative to OEM
Neal
Old May 13, 2023 | 09:36 PM
Originally Posted by legerwn
ac delco is not oem, they are the aftermarket side of gm, they offer replacement parts for gm vehicles, they are a very good alternative to oem
neal
RECAP: AcDelco distributes- GM assembles- Timken manufactures OEM.
Old May 18, 2023 | 03:35 PM
tharber's Avatar
You will be miles ahead if you get the rear main seal pre installed with the back plate. They can sometimes be a pain in the butt to align and if they are not just so, they will leak. Also you will have to drop transmission and transfer case to get to it.
Tim
