04 hummer h2 runs very rough
Old Jan 1, 2018 | 11:47 AM
rsh_86's Avatar
Default 04 hummer h2 runs very rough
im not good in english , but i hope you can understand and help.
first , a couple of months ago when driving all of a sudden the began to shake/vibrate
more than uasual and lost performance but it could still run. i read the codes and it was p0300. but after a few
days of using the truck i noticed it was wet around the exhaust manifold on cylinder 1 tried a new coil ,
plug and wire on that cylinder and it didnt help it. and dint have to much time to look more at it untill now.
i tried til replace all plugs , wires , maf and injectors and still dint help.
then i decided to try and take off the valve cover on the driver side and there i found the rocker
arm on intake valve on cyl1 was loose and the valve wasnt working.
checked the pushrod and rockerarm , the bolt and threads in the cylinder head and all was ok.
i put it all toghether and thightend it to 30nm , put the cover and coil packs back. and started. and it ran fine now.
BUT after 10-20mins of driving it begins to hesitate and runs very rough when driving and idling ,
i have to use 1. gear to get up small hills , and if i give it full throttle then it seems to work well.
now it throws code : P0101 , p0102 , p0171 , p0327 , p0332 , p0300
could this have something to do with the catalyc converter? i have been using the truck some when the cylinder1 wasnt woriking ,
and could this have filled the c.converter with gas and killed it ?
any suggestion ?
Aaroneaton87
Dec 17, 2017 12:11 AM
Don Janovyak
Jul 24, 2015 07:01 AM
Llamafood
Jan 11, 2012 07:16 PM
CHINAHummerGirls
Aug 19, 2010 03:36 PM
xzachx2112
Jan 11, 2008 06:20 PM
