03 H2 Catalytic Converter Replacement
Old Oct 9, 2014 | 06:55 PM
bad70ss454's Avatar
Default 03 H2 Catalytic Converter Replacement
I just got my H2 back after 2 weeks in the shop and I was told that I need to replace both converters for the engine light to go out. The code is showing a bad cat but I was told to replace them both. I purchased 2 new 02 sensors but they heated them up and still couldn't get them out. I was told to change the entire Y with the cats because they couldn't get them out. Anyone do that and what products do you guys think is the best?
Old Oct 10, 2014 | 05:34 AM
elkgrunt's Avatar
I did the same to mine, if you look on-line you will be able to get a direct fit.
Old Oct 10, 2014 | 07:57 AM
calif phil's Avatar
Try a muffler shop. If your cats are OK and all you need is new 02 sensors they can drill a hole and weld new 02 sensor bungs right next to the original sensors. If your cats are shot then yes a new Y pipe is in order.
kseaman
Jan 24, 2013 07:52 PM
bobh002
Nov 29, 2011 06:37 PM
hmmrgrl
Aug 29, 2011 08:34 PM
Bronx
Apr 16, 2008 05:49 AM
hummer_04
Jul 12, 2007 12:21 AM
