New here and have a ?
Old Mar 29, 2018 | 04:06 PM
Ronny Sawiki's Avatar
Default New here and have a ?
So I was told that the bolt at the bottom is a bushing that on all wheel drive vehicles. This bushing can cause CV axles to fail if this is bad. My question is what is it, how do I replace it and how hard is this to do?
Old Mar 30, 2018 | 10:26 AM
Front differential cross member bushing.
Couple ways to fix it.
Buy a new cross member from GM $300+ easiest.
Replace all 3 of the differential the bushings with an Outfitter Design bushing kit https://www.outfitterdesign.com/do-i...shing-kit.html
Old Mar 30, 2018 | 01:16 PM
Welcome to HF.
You posted your tech question in the WRONG section, so I moved it. The new member section is for : hello I am a new guy.... yada yada. It says in a thread stuck at the top, ... THIS SECTION IS NOT FOR TECH QUESTIONS!!
Tainter has it covered, but others might explain what it is for beyond holding the front diff in position for the front prop shaft out of the T case.
Old Mar 30, 2018 | 10:26 PM
thanks so much for the reply.. I was wondering if this could cause CV axles to fail on a regular basis? Thanks in advance!
Old Mar 31, 2018 | 01:30 AM
Happy Hummer's Avatar
Hello & welcome...
Google is your friend...
https://www.google.com/search?q=diff...obile&ie=UTF-8
Just a quick cursory search. I'm sure this will give you more then enough to read.
Old Apr 1, 2018 | 08:00 AM
Shouldn't effect the half shafts. If you look at it as an entire assembly the movement of the front diff with a bad cross member bushing will rotate with the half shaft not bind them. A bad cross member bushing will effect the front prop shaft (drive shaft), diff front seal, output shaft and seal on the Tcase.
What do the left and right differential mounts look like?
What is failing with your half shafts? Street driven or OffRoad? aftermarket wheels? Any other front suspension mods? What is your front height frothed center hub to the bottom of the fender?
sammy
Sep 8, 2011 02:20 PM
panzerman
Aug 3, 2011 01:55 PM
Tayman
Dec 24, 2008 11:43 AM
spusoccer
Jun 27, 2008 08:16 PM
GregDiesel
Apr 13, 2006 03:57 AM
