My H3T double-DIN factory radio died
Old Jan 13, 2022 | 09:43 AM
Nokomis's Avatar
Thanks. Ordered, but from WalMart Online ($2 cheaper but mainly gets here faster). Good to know that the brake wire is ground instead of hot. I can ground it to the chassis manually (twice) long enough to pair my phone, then install the hack when it arrives next week.
Thanks again, your help is a big timesaver and truly appreciated.
Old Jan 15, 2022 | 01:17 AM
Nokomis's Avatar
RESOLVED -
The sound was pretty crappy, as I mentioned. And TAINTER was correct; the amp is fed from the single connection - the unused RCA amp plugs on the 2nd cable would be used in the case of an aftermarket amp instead of the Monsoon amp. I called Crutchfield support, and they verified that I had connected everything correctly. And then the guy said OH WAIT - check and see if we plugged the cable into the correct slot on the Crux - one side is for Bose (Monsoon) equipment, the other is not. So I swapped the connection on the Crux and powered up, and BAM!! I had my full range of volume, bass, and clarity. This stereo sounds GREAT! I still have to install the rear camera and the parking brake faker-outer when it arrives, but at least now I've got tunes again.
Old Jan 23, 2022 | 10:29 AM
factfive's Avatar
Nice work...post some pics up of the unit installed.Interested in this upgrade for my 10' T.Thanks
Old Jan 23, 2022 | 11:09 AM
Nokomis's Avatar
Will do, but it'll be a few days. Still need to install the Parking Brake faker-outer and drill a hole for the USB plug and I haven't yet installed the reverse camera. But as far as the sound, it's great even with the factory speakers, and I couldn't ask for a better "factory looking" install.
One thing the Crutchfield website asks in their selection process is "Do you want ***** or all touchscreen?" and I selected touchscreen simply because I figured it would give the screen more real estate. Now that it's installed, I miss the ***** - I can't quickly turn the volume up and down; it's either look at the radio to find the volume +/- buttons and wait for them to count up/down, or look at the radio to find the mute button. With the ****, I could instinctively find it and adjust the volume immediately without looking. Sometimes you don't have precious milliseconds to waste getting it cranked it up, such as when "Stranglehold" or Thunderstruck" comes on.
dougie
Oct 8, 2017 02:10 PM
thorg113
Jul 21, 2015 08:33 AM
Ken06H3
May 17, 2007 10:14 PM
hummerfun
Jan 16, 2007 03:09 PM
fatdog77
Jul 17, 2006 06:43 PM
