H3T Rancho Lift, wana be another Rockstar wheels with Fox shocks...
Old 11-02-2010, 09:07 PM
jbetz's Avatar
Default H3T Rancho Lift, wana be another Rockstar wheels with Fox shocks...
Old 11-15-2010, 10:52 PM
jamesdz1's Avatar
Default How do you like the Fox Shocks?
I was trying to find the Fox remote reservoir shocks for my 4" lifted H3 Alpha, but all I could find were the units designed for stock ride height. How are yours working and what is the model number.....
Old 05-19-2011, 10:05 AM
Alpha14's Avatar
I am also looking for these shocks to use with the 4" Rancho lift and am not sure which ones they are... Could you help me out?
Old 07-23-2011, 05:58 PM
jamesdz1's Avatar
Default Fox shocks and 4" lift
I installed the shocks, but it required welding new upper mounts in the front.
Old 07-26-2011, 05:55 PM
Alpha14's Avatar
I am still trying to find out what model these shocks are and if you had to custom order them or if they are just hard to find? I can't find them anywhere online that are compatible with the 4" Rancho lift... Could one of yall help me out?
Old 07-28-2011, 03:33 PM
jbetz's Avatar
Sorry guys, I don't log on here very often.
I did the leg work and placed a custom order through ORW
Off Road Warehouse -
Talk to Nick
1800-341-7757
Mine were a direct bolt on other than swapping the lower stock shock bushing into the new Fox units.
My order was under Bahn Brenner Motorsport, LLC
Feel free to have Nick reference my order for these Fox shock specs.
Old 07-28-2011, 03:43 PM
jbetz's Avatar
Next is rock bars / steps, bush whackers, some ice and an LS2 swap &TVS blower
I'm looking at an 06 GTO for the loaner engine... I'll inquire here before I pull this trigger.
If you guys want to run bush wackers you can order three front sets. They only make these for the H3 SUV. You can splice two front sets into a decent fitting rear set. I'll post pics when I'm done with this new install.
Cheers
Old 07-28-2011, 04:55 PM
Not sure what the difference is between Bushwhacker and E&G, but E&G makes flares designed specifically for the H3T...
Old 07-28-2011, 08:02 PM
jbetz's Avatar
I had no idea these were out there so thank you for this info.
Cheers
Old 07-29-2011, 11:16 AM
Alpha14's Avatar
Ok cool, thanks for the info!
And yea I am getting the E&G flares when I lift mine! They look good!
H3Ray
12-17-2012 06:17 AM
lovergoof
09-09-2012 09:22 PM
FilthyKings
05-16-2012 02:40 PM
ava327
18
12-20-2011 02:00 AM
haiminger
20
02-11-2008 08:12 PM
Quick Reply: H3T Rancho Lift, wana be another Rockstar wheels with Fox shocks...
