Wire hold down
Old Feb 18, 2020 | 05:15 PM
aku96778's Avatar
Default Wire hold down
I have a 2007 H3 and on the upper control arms there is a hold down for the wheel sensor cable. Does anyone know what the part number is?
Mahalo Nui Loa
Old Feb 18, 2020 | 07:39 PM
Old Feb 19, 2020 | 07:04 AM
Please disregard the post above this. That is for the speed sensor not the clip/bracket you asked about.
The metal clip that holds the Wheel Speed Sensor to the upper control arm is below.
Not sure which one you need.
GM Part Nos.: 25792759 (25792760)
Bracket,Wheel Speed Sensor: Part Description BRACKET, Electronic Brake Control : Left (Right)
#11 in the image below.
https://nemigaparts.com/cat_spares/e...n/04/tn04-105/
Old Feb 19, 2020 | 09:30 AM
aku96778's Avatar
Thanks, I'll order. The one that I do have is plastic. Will see what show's up.
Old Feb 19, 2020 | 12:56 PM
Plastic?
Then it may be # 6 in the diagram
006 CLIP, WHL SPD SEN WIRE(PART OF 4, 7)(GRAY)(14. 5X16X25)(HOLDS (1)10 ABS WIRE GROMMET, DUAL TREES) N1 15175330 - -
Brent Whitfield
Feb 12, 2014 06:40 PM
wet_rat
Jul 8, 2010 09:52 PM
motley1987
Mar 13, 2010 03:25 AM
GRS
Aug 25, 2009 07:58 AM
jrbnc
Apr 27, 2009 02:36 PM
