Windshield Washer (front) issue
Old Nov 26, 2019 | 05:18 PM
esfop319's Avatar
Default Windshield Washer (front) issue
Okay, this is baffling me ....On my '07 Hummer H3, when I turn on the rear windshield wiper and press the washer, fluid comes out and I hear the pump.... But, when I turn the front windshield wipers on and press the washer, I don't hear the pump or any fluid comes out but the wipers work on both. I checked the fuses and all are good. Any advice would be greatly appreciated.
Old Nov 26, 2019 | 05:35 PM
check/test the connector at the front pump.
Old Nov 26, 2019 | 05:52 PM
650Hawk's Avatar
There's only one tank, but 2 pumps.
Old Nov 26, 2019 | 06:02 PM
esfop319's Avatar
TWO PUMPS? I did not know that...I thought one pump fed both washers... Where are the pumps located? Thank you!
Old Nov 26, 2019 | 06:09 PM
Both mounted on the reservoir.
Old Nov 26, 2019 | 06:48 PM
esfop319's Avatar
Thank you guys and or gals!
Old Nov 27, 2019 | 03:12 PM
esfop319's Avatar
Default windshield wiper pump followup
FOLLOWUP: Took out the Air cleaner unit and removed bolts holding windshield washer canister and coolant canister.... found that someone before me removed the front windshield wiper washer pump plug. I plugged it back in and all is good (so far). I was wondering, why it was removed in the first place. Guess if there was an issue, I will find out down the road.....Anyway, thanks for the advice.
Old Nov 27, 2019 | 04:07 PM
Replaced pump without securing the connector. Plug and tug to make sure it's properly connected.
Old Nov 27, 2019 | 05:00 PM
esfop319's Avatar
Default Windshield pump Plug secure
I did plug the unit in until I heard the snap and the tab on the plug was secure...Tried pulling on it, all is good! Thanks for the advice and help.... GREAT people and forum.
SIMMS156
Mar 4, 2023 11:31 PM
Mike6208
Mar 28, 2020 01:48 PM
luke1213
Feb 17, 2016 10:29 AM
armarto
Jan 20, 2010 12:31 PM
