Will Ford Bronco rims work ?
Old Oct 2, 2023 | 06:32 PM
sjjohansen's Avatar
Default Will Ford Bronco rims work ?
I have a 2007 Hummer H3. I need new tires and I see a lot of tires and rims for sale from the new Ford Bronco. They have the same pattern 6X139.7 so I believe they will fit but just want to make sure before I buy them.
Old Oct 2, 2023 | 07:21 PM
Happy Hummer's Avatar
You'll want to make sure the back spacing 5.75" backspacing, +38mm offset will work as well as the hub centric circle 100.1 mm.
This Hummer H3 wheel has 6 lug holes and a bolt pattern of 139.7.
The offset is
36-40mm
6x5.5 and 7.5"
Old Oct 2, 2023 | 07:25 PM
Are Bronco wheels hub centric? Kind of important huh?
Old Oct 2, 2023 | 10:01 PM
sjjohansen's Avatar
Default Bronco rims
Thanks for the info. The Bronco rims won’t work. The center bore is 93.1 mm and the H3 is 100
Old Oct 3, 2023 | 06:37 PM
That's not quite true. If there is enough meat around the hole you could machine them out to 100mm.
Something as simple as a air die grinder would work nicely.
Old Oct 3, 2023 | 09:08 PM
sjjohansen's Avatar
Bronco wheels are lug centric.
Old Oct 4, 2023 | 11:50 AM
Then sadly that is gonna put a fork in this thread haha!
john michael
Dec 1, 2010 09:40 AM
Radoc
Jul 27, 2008 07:44 AM
audil
Sep 13, 2007 10:53 PM
melvynray
Mar 8, 2007 08:47 AM
crc2k
Aug 31, 2006 03:30 AM
