will faulty BCM keep 4WD from engaging
Old Jul 27, 2020 | 06:33 AM
Champion@1956's Avatar
Default will faulty BCM keep 4WD from engaging
Just purchased a 2007 H3 and took it to a local dealer for a general check up. It was displaying service 4WD and was advised that the encoder motor was bad
and also the BCM which was not allowing the key fobs to be programmed. The question is can these issues be related? Can the BCM keep the encoder motor
from operating?
Old Jul 27, 2020 | 09:40 AM
Sunroof on your newly purchased H3?
Old Jul 27, 2020 | 10:28 AM
Yes and it did leak in the past but that has been corrected
Old Jul 28, 2020 | 03:04 PM
Originally Posted by Champion@1956
Can the BCM keep the encoder motor from operating?
Unrelated. The dealer is the LAST place to take any out of warranty vehicle for diagnosis or work. It's easy to say the encoder motor is bad, but it is just as easy to get under the truck, check the connector and harness to the encoder motor, clean them with electrical contact cleaner, and then test for function. If still no go, test for voltage at the connector.
If the sunroof leaked a bunch, the TCCM can be shorted or corroded as well, which could effect your ability to select a transfer case mode.
FloridaH3t
Hummer H3T
20
Oct 24, 2018 08:54 PM
dognut
May 17, 2017 05:59 PM
Hitmanpty
26
Jan 4, 2017 07:31 PM
vacman
Mar 17, 2016 10:52 AM
drag791
Apr 21, 2011 06:40 PM
