Will a 2007 3.7 be compatable in a 2009
Old Jan 26, 2016 | 08:36 PM
Heebie3's Avatar
Default Will a 2007 3.7 be compatable in a 2009
I have a 2009 H3t with a 3.7 and it needs a new motor. I found a 2007 3.7 but I am wondering if I will have issues with the PCM.
Old Jan 27, 2016 | 08:14 AM
Welcome. Your post was MOVED from the new member area to the H3T section because you are asking a technical question instead of providing an introduction.
Your PCM will have to be reprogrammed.
Old Jan 27, 2016 | 08:45 PM
Heebie3's Avatar
Thank you, anything else I should be aware of
Old Jan 29, 2016 | 12:36 PM
I am going to assume that you will be using your 2009 throttle body with the 2007 motor when it is dropped in. You should be aware that the the 2008 and newer throttle bodies are slightly different than the earlier 2006/7 TBs.
Other than that, your plan should work fairly smooth.
Old Mar 25, 2020 | 01:22 PM
Heebie3's Avatar
Default H3 wiring
Thank you very much. Now I have a few different solutions.
Heebie
lobster-overlord
Sep 15, 2014 07:57 AM
Alfieg23
Oct 24, 2009 04:04 PM
pmalla5
30
Nov 13, 2007 09:25 PM
HummerGuy
Oct 17, 2006 12:17 PM
HummerGuy
29
Sep 1, 2006 12:05 PM
