Where: loose passenger airbag connections?
Old Feb 2, 2022 | 02:34 PM
Old Feb 11, 2022 | 02:26 PM
mikesbaron's Avatar
The e-brake reset procedure didn't work. Guess I'll pull the kick panel and try to clean and check the airbag connection there.
Is there any other connection I can check and clean before I got to the BCM replacement?
Old Feb 11, 2022 | 02:37 PM
I do not think you need a BCM replacement. My bet is still on an SRS Module replacement if after you clean up connections and the problem continues.
Good luck.
Old Feb 11, 2022 | 08:01 PM
9 day delay, without progress? BCM? fuh·ged·da·boud·it. Find someone that knows how to DIAGNOSE!
Old Mar 12, 2022 | 10:11 PM
mikesbaron's Avatar
Figure I might as well check my passenger airbag connections. Where are these connectors that you show here, are they front passenger? I pulled my lower kickpanel (front passenger) to try and find mine but they look nothing like the ones you posted.
Old Mar 13, 2022 | 04:26 PM
Drivers side
julijulez24
Jul 16, 2020 11:49 PM
CLajoie222
Nov 18, 2018 09:30 PM
NorthstarH2
Oct 23, 2016 04:43 PM
Biglou
Nov 29, 2015 08:45 AM
BigDawg99
May 8, 2011 01:57 PM
