What limited slip or locker for rear 2006 H3 do you recommend
Old Feb 7, 2021 | 07:11 PM
Newaf's Avatar
Default What limited slip or locker for rear 2006 H3 do you recommend
New H3 owner and I have read so far that it’s not ok to run a locker in the front differential with this year, what are you guys running for rear lockers or limited slip?
Old Feb 8, 2021 | 07:06 AM
Eaton E-Locker (factory)
Old Feb 8, 2021 | 08:55 AM
You can put a front Eaton E-Locker from and 09-10 into the front diff of a 2006/07/08.
Old Feb 8, 2021 | 12:43 PM
Newaf's Avatar
seems like that is the way to go, thanks guys mine is a 2006 so no front locker without upgrading the differential..
Old Feb 8, 2021 | 02:09 PM
It is an easy one, find a front diff from a 2009/10 I5 Adventure, they are cast iron. Swap the entire front diff carrier and all, then wire your switch..
Old Feb 9, 2021 | 05:53 AM
I would NEVER recommend installing any kind of locker into the aluminum front differential.
It is doing all it can to stay together without the stress of a locker on the aluminum case.
Old Feb 9, 2021 | 09:27 AM
Me either. Like I said, swap the entire front diff. I5 to I5.
Tom Cruz
Oct 11, 2019 04:26 PM
keeldragger
Oct 8, 2008 10:33 PM
T REX
Jun 23, 2008 12:07 AM
ozHummer
Apr 28, 2008 04:26 PM
blackbear
Nov 8, 2006 06:49 PM
