What is this knocking sound?
Old Nov 20, 2021 | 07:42 PM
Shorty's Avatar
Default What is this knocking sound?
What is this knocking sound? Its seems to happen when I give the car sudden throttle from slow speeds.
Video of front drive shaft cv:
Video of front wheel:
Old Nov 22, 2021 | 09:41 AM
Can't hear whatever you are concerned about from your vids.
Good luck.
Old Nov 22, 2021 | 02:52 PM
Raise front wheels off the ground and check front driveshaft cv joint, look/listen at :35 here:
Old Nov 23, 2021 | 05:32 AM
Shorty's Avatar
Think im getting closer... at 2:52 you can see the front diff rise up and flick back down causing vibration in the under guard
Old Nov 23, 2021 | 07:34 AM
Rear diff bushing, either side diff bushing would be my guess if everything else is tight. Have you checked the mounting bolts to the frame on the front diff mounts?
Old Nov 23, 2021 | 05:26 PM
https://youtu.be/q8jkfKBWMRk?t=172
You should have a ((((((warning "brake squeal"))))). Replace those brake pads ASAP! My ears are still ringing listening on my 7.1 surround connected to my pc.
Did you get under and inspect/check front diff bushings and propeller?
Old Nov 23, 2021 | 11:07 PM
Shorty's Avatar
Here is a video of the front diff bushing. You can see it really moving up and down.
I only recently put this new bushing in so I'm thinking I installed it wrong or maybe its poor quality.
Am I right this is the problem?
Old Nov 24, 2021 | 09:53 AM
https://youtu.be/BTdr7dPKmLo
Yep, I think you found your issue. There is supposed to be ability for "some" movement, but you have way too much.
Do it up right here.... H3 D.I.Y. FRONT DIFFERENTIAL BUSHING KIT
Old Nov 24, 2021 | 10:36 AM
Justinh's Avatar
That looks scary. Do the engine mounts need to be changed also? (The oil pan is swinging over big time.)
Old Nov 24, 2021 | 11:47 AM
