water soaked floor padding
Old 05-06-2019, 01:44 AM
happythree's Avatar
Default water soaked floor padding
i pulled the trim under the back hatch to run a wire. noticed damp dust. i lifted the floor pad and it was soaked,dripping!
pulling it out was an exercise,moving the rear seat that i had just reinstalled last week,pulling the side panels and window trim,a teardown.
im laying it out for a few days of ,rare, sunshine.
wonder how water gets in a good tight hatch.
im amazed that there is zero rust,my jeeps would be rusted away by now, epoxy paint??
its a 2010 and it looks factory fresh! lucky me.
but a warning,i cant be alone with this...check it out...
Old 05-06-2019, 10:26 AM
Dr Tom,
Either your rear sunroof drain tubes are doing it or it the holes where the fender flares attach https://www.hummerforums.com/forum/h...-soaked-40795/
Old 05-06-2019, 08:50 PM
Sunroof drains! I checked my sunroof seal yesterday, and found a lot of debris stuck between the seal. Cleaned out.
I removed the rear seats many years ago, and all is still dry.
Old 05-06-2019, 09:26 PM
happythree's Avatar
Default dont think sunroof
i never have roof leak problems, . check drains and water runs where it should,not inside.
i usually park down hill and im not 'leveled",like rake!
Old 05-07-2019, 10:03 PM
HumbleAg's Avatar
Originally Posted by TAINTER
Dr Tom,
Yeah, I was pretty surprised by mine as well. Siliconed over the clips and hosed it down good before I put it back together, seemed ok. However, I have it in my barn doing other stuff (valve cover emplacement because of clogged passages and failed seals, thermostat and ECT sensor because of AC off message) so it hasn’t been out in the rain.
jbs45
11-01-2021 11:38 AM
rstaub
33
06-14-2014 06:11 PM
derf911
07-24-2011 01:31 PM
amyandmark3
07-19-2011 01:56 PM
radioactivesob
04-19-2011 07:22 PM
Quick Reply: water soaked floor padding
