Vibration Driving me nuts
Old Nov 8, 2018 | 05:11 PM
Matt Curry's Avatar
Default Vibration Driving me nuts
Really hoping someone has an idea here.
Have had a vibration in my h3 for about a year now. The vibration is pretty heavy and towards the center of the car. I can feel it under me as I drive. It only happens under load and is at its worst at 50 mph. If I take my foot off the gas or shift into neutral it goes away. My rpms are not bouncing and I can drive through it with no problem.
- have new tires
- alignments good and everything’s balanced
- mechanic had it for days checking u joints cv axles, tire rods etc etc. found nothing!
- only suggestion was to change trans fluid. The trucks at 82,000 miles.
Im at a loss here. I don’t want to start throwing money at it guessing as I had the engine rebuilt 2 months ago. If anyone has an ideas I’d appreciate it.
Old Nov 9, 2018 | 10:31 AM
Is the vibration felt in the seat or the steering wheel?
Old Nov 9, 2018 | 10:37 AM
Get under it, grab the front drive shaft and see if you have any play at the CV joint.
Carefully inspect the rear drive shaft, does it still have the balancing weight from the factory attached, any dents?
Old Nov 11, 2018 | 09:54 AM
Chimpy's Avatar
Just replaced both U-joints on the rear prop shaft on my 06 and all vibration is gone. I went with Spicer U-joints which have the zerk fittings. Took about an hour and a half, now it is smooth and quiet going down the road.
Chimpy
Feb 23, 2018 04:59 PM
Mkawas
Oct 6, 2017 10:09 AM
xtremez28
Dec 15, 2014 03:13 PM
wkrpinnick
Jun 24, 2011 07:40 AM
Jlando
Dec 25, 2008 10:15 AM
