Very Important ECu to BCM "QUESTION"
Since H3s use a PCM, not an ECU, I think there is some confusion?
If what you are asking is: Will a stock 07 PCM work in a stock 06? The answer is NO.
07 PCMs will not work in an 08 because of the TCM. 08-10s are interchangable so long as the engine/trans pkg is the same.
not a 2008..... 2007 computer with an 06 bcm
I agree with Tainter and the SIR issue. Aside from that, its a CAN system where all modules communicate back and forth with each other. Anything from A/C system operation to putting it in drive could be affected. But more importantly, why would you want so switch it?
02-19-2014 12:54 PM
CHINAHummerGirls
08-19-2010 03:36 PM
rocky27_9
01-27-2008 02:29 AM
