Very Important ECu to BCM "QUESTION"
Old Sep 22, 2010 | 06:20 AM
FilthyKings's Avatar
Default Very Important ECu to BCM "QUESTION"
444444444444444
Old Sep 22, 2010 | 08:33 AM
85_305's Avatar
Banned
I'm thinking ANY bcm will work; but you have a very good chance of needing to go to the dealer and have it reprogrammed.
Old Sep 22, 2010 | 10:26 AM
Since H3s use a PCM, not an ECU, I think there is some confusion?
If what you are asking is: Will a stock 07 PCM work in a stock 06? The answer is NO.
07 PCMs will not work in an 08 because of the TCM. 08-10s are interchangable so long as the engine/trans pkg is the same.
Old Sep 22, 2010 | 11:09 AM
85_305's Avatar
Banned
Interesting; I thought they were all somewhat compatible, just the dealer had to reprogram them for your individual case?
Old Sep 22, 2010 | 03:34 PM
not a 2008..... 2007 computer with an 06 bcm
Old Sep 22, 2010 | 09:45 PM
I believe that a BCM (Body Control Module) from an 06 will not work in an 07 due to the fact that the 06 did not have SIRs (Side Impact Restraints/airbags) and most of the 07s did.
Old Sep 23, 2010 | 05:05 PM
Chunk54's Avatar
I agree with Tainter and the SIR issue. Aside from that, its a CAN system where all modules communicate back and forth with each other. Anything from A/C system operation to putting it in drive could be affected. But more importantly, why would you want so switch it?
Old Sep 24, 2010 | 08:13 AM
Feb 19, 2014 12:54 PM
wantboost
16
Sep 8, 2010 06:32 PM
CHINAHummerGirls
Aug 19, 2010 03:36 PM
rocky27_9
Jan 27, 2008 02:29 AM
xzachx2112
Jan 11, 2008 06:20 PM
