U joints size
Old Nov 22, 2019 | 05:59 PM
H3Luxembourg's Avatar
Not really. It is surmised (I did some looking but found nothing conclusive) that the non-greasers are stronger?
The Dana Spicer 1350 series is hard to beat, they look cool too. I got some pics somewhere, not on this computer.
Thanks Bro. So the rear trans has two U joints right? that makes 3 U Joints and one CV joint... well i will see if they are all available.... over here. I just have a little play at the front Ujoint but i never change only one, i change all of them.
Old Nov 22, 2019 | 06:23 PM
Just to be clear, if you only need front brakes, you will replace all the brakes at the same time?
What propeller shaft has play? Recommended to remove and replace both joints at the same time. Btw, if you get any play in the other shaft you will know what to do.
Thanks Doc, will remember that.
Doc , a special reason for using non-greasables? Always thought they're better, like, i only have greasables on my 1991 Suzuki Samurai and never had issues?
You are living on the edge with your 1991 Suzuki Samurai.
Old Nov 26, 2019 | 02:59 PM
wthat propeller shaft has play?
Exactly, i never replace only front or rear brakes, the power of braking and braking way will be different.
= front U joint has play
--> yes always replacing both at same time, will probably change the rear too.
and I know, love my Samurai it's the second one.
Old Nov 26, 2019 | 05:14 PM
My point brakes in pairs same as I do u-joints. Go ahead and get all the parts, however if you only have play on 1 shaft, remove it and replace both joints. Save the other joints when you find play in the other shaft.
Old Nov 27, 2019 | 12:35 PM
Personally, i change them all so they are good for the next 100k Km
Old Nov 27, 2019 | 05:53 PM
Personally, if it ain't broke, don't fix it. I'm a huge fan of preventive maintenance, however I don't see the need to replace parts that are still performing as intended. If you have a joint that has gone bad on a propeller shaft, I recommend to replace both joints on that shaft, since there is most likely wear on the other joint. Also, If you have worn brake pads on the right front, it's best to change both fronts since you will have a variance in braking(side to side). Yet, that does not cause for concern to replace the rear brake pads, which normally lasts 2x longer than the front brake pads. Btw, 100k miles will drastically change when you have a failing caliper. I never look that far ahead, yet I have my parts ready, if needed.
Old Dec 2, 2019 | 01:15 PM
Well i will follow your idea and just replace the both at front, the rear doesn't show signs of play.
Justinh
Jan 10, 2017 08:22 AM
pears
Sep 19, 2016 07:07 PM
BERULAKIDE
Apr 20, 2014 05:09 PM
Mcpousnret
Jan 21, 2014 12:21 PM
joenuzz
Apr 12, 2011 06:32 PM
