Turnng of the DRL on 2006 H3?
Old 06-26-2011, 11:16 AM
Andreas_Sweden's Avatar
Default Turnng of the DRL on 2006 H3?
Is it possible to turn of the DRL on the H3? So they don't turn on automatically every time I start? Is there a trick to do it by yourself or do you need a mechanic do it with a TechII? Or is it impossible all together?
Old 06-26-2011, 01:17 PM
drtom's Avatar
Banned
pull the drl fuse
Old 06-26-2011, 01:40 PM
Originally Posted by drtom
pull the drl fuse
Thanks,
didn't know that the DRL had a fuse of its own.
Old 06-26-2011, 01:59 PM
Do you know which fuse it is can't find it in the owners manual
Old 06-26-2011, 11:17 PM
I'm not advocating removal of the fuse for the DRLs but if you needed to replace it? My 08 and 09 manuals say it is in position #39 (Reduced Intensity Low-Beam Daytime Running Lamps).
Old 06-27-2011, 05:09 AM
Broken Halo's Avatar
There may not be a separate fuse/relay for the '06, since it used the parking lights for DRL,s, and didn't need to 'reduce intensity' for the headlamps as used on later years. Not sure, but I think the DRL's were 'full intensity' parking lamps.
Ta Jay
09-23-2022 01:35 PM
jlopez
08-30-2013 06:28 PM
D VADER
17
11-05-2007 03:56 PM
D VADER
20
07-23-2007 06:18 AM
D VADER
06-29-2007 02:55 PM
Quick Reply: Turnng of the DRL on 2006 H3?
