Transmission Fluid Change...More Harm Than Good?
Old Aug 23, 2020 | 03:23 PM
Originally Posted by TAINTER
That's why you install the drain plug. After 50 miles, drain & fill. Repeat the process until you have nice red fluid. Not a trans flush person, NEVER will be. Have a 1964 power glide with just fluid changes on it with over 275,000 miles still shifts very well. Excursion with 225,000 miles never flushed, just changed and tows 10k+ regularly. That's my proof. My own vehicles. Not some Amsoil (snake oil) krap I read on the internet.
That's another way to do it? However, with 16quarts fresh dexVI and 15 minutes, running through a fluid exchange machine, the fluid is new again! Draining only portion of the fluid, mixes remaining old fluid again with the new fluid. Check out a transmission fluid exchange machine, you will be impressed at how effective it is. Many years of performing this service and there were times that took more than 16qts to clean the fluid, yet always positive results when completed.
Old Nov 30, 2024 | 09:51 AM
Originally Posted by jovoke
If the fluid isn’t severely degraded (burnt smell or gritty texture), go ahead with a fluid and filter change—it can help extend the life of your transmission. If it’s badly worn, consider a partial fluid change instead of a full flush to reduce risk. Leaving old fluid in will likely lead to faster wear, so it’s better to act now. If the shop advises against a change, ask for a clear explanation and consider a second opinion.
You keep digging up Old Azzed Threads you will not be here much longer. I already asked that you please stop that practice.
cjd9153
Jun 5, 2019 10:55 AM
cjd9153
20
Jun 3, 2019 01:28 PM
2005H2
Jul 12, 2017 02:39 AM
zzpw3x
41
Jun 10, 2015 08:00 PM
jrv435
Jul 15, 2012 08:10 PM
