Transmission Fluid Change...More Harm Than Good?
Old Aug 21, 2020 | 02:36 PM
HHOhummer's Avatar
Default Transmission Fluid Change...More Harm Than Good?
Hi Everyone:
I bought my 2008 H3 Adventure at a dealer with 53k miles.
I had assumed they had changed the automatic transmission fluid during the time they had it but now I'm not sure.
Now at 79600 miles I made an appointment with a tranny shop to have the fluid and filter changed.
The guy said that they will have to check the fluid and if it looks worn, will recommend I NOT change it because it could do more harm than good.
Could someone give me some insight on this?
Has anyone else faced this?
If I don't change it, does this mean my tranny is doomed to fail shortly? At the moment it shifts/works/sounds fine.
Just curious if they recommend I don't change the fluid, what I should do.
Thank you
Old Aug 21, 2020 | 03:02 PM
Pull the dipstick and wipe on a white paper towel. Give it sniff too.. Black and smell burnt? If so your f'cked.
If not, and not knowing the maintenance history, I recommend a complete flush+filter change. Refill with
Amazon Amazon
Btw, I DO NOT RECOMMEND ANY SERVICE AT A TRANSMISSION SHOP!
Just find a reputable auto repair that can perform a transmission flush, and drop the pan to change the filter, and BYOTF, (4 gallons should be enough, click on link above to save money)
Old Aug 21, 2020 | 03:30 PM
HHOhummer's Avatar
Much thanks my Hummer brother, just checked and it's between red and light brown and semi-transparent.
The dealer must have changed it when they had it.
Old Aug 21, 2020 | 03:43 PM
You're good then, get some fluid and diy flush or drop pan & replace filter too, or take to shop and flush cheap/ or drop pan and replace filter too, cheaper when you bring your own fluid. Just be sure to avoid the transmission shops until you need a transmission, they are in business to sell transmissions, not fluid changes.
Old Aug 22, 2020 | 04:06 PM
Never flush, always drop the pan and replace the filter instead. While you have the pan off add a drain plug yo the OEM pan. 👍
Old Aug 22, 2020 | 05:53 PM
Not sure what you're smoking? Pan drop is only 1/3 fluid change. Flush/fluid exchanges all transmission fluid.
You don't change 1/3 of your engine oil, so why only change 1/3 of your transmission fluid? I recommend a flush every 15k miles and filter change every 30k miles.
More info here: Transmission Flush vs Fluid Change: Which is Better?
Old Aug 23, 2020 | 08:15 AM
Happy Hummer's Avatar
Please block all the wheels!
Old Aug 23, 2020 | 09:31 AM
RKSmith163's Avatar
I alternate. Flush and Pan Drop every 30K.
Old Aug 23, 2020 | 12:14 PM
BlueH3's Avatar
90K - I had mine pulled from dipstick line exchange at shop and was definitely was dark maroon reddish. Nice to have fresh fluid in and feel the crisper shifts.
Old Aug 23, 2020 | 02:46 PM
That's why you install the drain plug. After 50 miles, drain & fill. Repeat the process until you have nice red fluid. Not a trans flush person, NEVER will be. Have a 1964 power glide with just fluid changes on it with over 275,000 miles still shifts very well. Excursion with 225,000 miles never flushed, just changed and tows 10k+ regularly. That's my proof. My own vehicles. Not some Amsoil (snake oil) krap I read on the internet.
