Transfer case leaking - seal replacement?
Hey guys,
Please check out the attached pic. I just noticed that the bottom of my transfer case is leaking (or maybe more like seeping) since its not dripping on the ground yet (red circled area). As far as I can tell, it appears to be coming from the point where the drive shaft connects to the transfer case (blue arrow). Is this a relatively easy fix? Is it just a matter of removing the drive shaft and replacing the seal in the transfer case? Also, if you have the part number for the seal it would be greatly appreciated. Thanks! Btw, this is for a 2006 H3 with manual transmission.
Do you know which seal is bad? Might want to replace them both if possible.
SEAL. Transfer Case
SEAL,TRFER CASE INPUT SHF. Required: 01
For: N1 AWD 2 SPD TRANSFER CASE(NR4),2-SPD AWD TRANSFER CASE(NR6) (2006-2010) (2006 - 2010).
88996656
or
SEAL. Transfer Case
SEAL,TRFER CASE FRT OUTPUT SHF. Required: 01
89059515
in this diagram are the seals and the #s.
SEAL. Transfer Case
88996656
or
SEAL. Transfer Case
89059515
UPDATE: Replaced rubber seal (#20 on diagram above). Cost me ~$45 at the dealer (probably cost about $2 to make btw). Anyway, the good news is that the leak is gone! Been driving for several days now and zero leakage or seeping. Whole job took about an hour.
Nice to meet everyone! There is a leak from my 2008 H3 as well, and I believe it is the #20 seal. I have removed the U-Joint end of the front propeller shaft and it is free. Do I need to remove the #21 Flange and #24 Nut to finish removing the propeller shaft, or does the propeller shaft just slide out? Thank you!
Wisconsin03H2
04-22-2019 09:40 PM
bigstick0000
11-28-2012 10:06 PM
